Flash13
Jun 19, 2022Aspirant
One of the two RBS750 not connecting as a satellite
I am having an issue with one of my RBS750 satellite which for some reason is not being recognized as a satellite by the RBR750 router. I have tried resetting the satellite as well as the Router, conn...
- Aug 22, 2022
Try admin and just plain password to see that logs you in?
What happens if you select the REMOVE button on the RBRs web page, then factory reset the #2 RBS and sync it manually using the sync button on the RBS then on the RBR? I would Turn OFF the 1st RBS and bring the 2nd RBS to same room or near the RBR for this.
Please edit out any MAC addresses or product serial numbers before posting in public forums for security reasons.
Jun 20, 2022Guru - Experienced User
what do you mean its not recognized as a satellite?
what is it showing?
What actual firmware is on both the satellites and the router? (not the latest, that doesn't help)
what happens if you try hardwiring the satellite into the router and syncing it?
what modem/gateway is the router connected to?
What method of connection are you using for the satellite? A wired backhaul? Using the wireless backhaul?
Flash13
Jun 20, 2022Aspirant
This is how it show up
