bullm00n
Jun 14, 2023Virtuoso
One problem is that if I try to get good info on Router / Satellite coverage
FURRYe38 wrote:
Yep. Having ANY MESH system in a small size home is going to be problematic with having too much wifi signals running around. Like a busy noise restaurant as an example. Kind of ...
Jun 14, 2023Guru - Experienced User
Can you draw up a home floor lay out and mark where you normally have the RBR and RBS placed and distances between the RBR and RBS and each other and post it here?
bullm00n
FURRYe38 wrote:Can you draw up a home floor lay out and mark where you normally have the RBR and RBS placed and distances between the RBR and RBS and each other and post it here?
So, the idea is coverage for each floor, coverage for cameras outside front, coverage for deck outside back. The RBRE960 is located near the demarcation point at the wiring panel with the xFi Modem and Netgear switch that is wired to most rooms. Sats are wired directly to the Router bypassing the switch. I could, with some minor gymnastics, put the router into the center of the house on the main floor temporarily to get better coverage with the Sats disabled if it comes to that.
