Kzoom
Oct 16, 2021Aspirant
one RBS750 'died', other one won't reconnect after testing power blocks
Hadn't looked at app in a while. RBR750 - green, one RBS750 - green, one RBS750 -red. Unplugged disconnected satellite. Plugged back in. Pale red light at power connector. No ring light at all. Not...
Kzoom
OK, the Satellite that was working before, then stopped during my tests, has come back up after pressing 'Reset' a couple of times with a paper clip.
So I think I just have a dead RBS750. Lovely.
Any warranty on this?
- FURRYe38Oct 17, 2021Guru - Experienced User
Contact NG support and check on what options you have available.
