oOo-MPD-oOo
Mar 08, 2022Tutor
One satellite not relaying guest wifi network (RBR850/RBS850)
Hi I have a RBR850 orbi router, with two RBS850 satellites connected via a wired connection One of the satellites has stopped transmitting the guest wifi network, the other satellite and main...
- Mar 21, 2022
Definitely something with the switch. I managed to directly connect the satellites to the router and everything magickly works. Is this an oddity with this switch or has anyone seen similar behaviour on other switches?
Mar 08, 2022Guru - Experienced User
what firmware version are you on?
There was just a release of new firmware on the official site yesterday
- oOo-MPD-oOoMar 08, 2022Tutor
Thanks for both responses - I should have included the firmware details, apologies. I'm running V4.6.3.16_2.0.51 on all three devices
I'm connected to a BT FTTP modem (unsure of exact version) - but would this really impact the guest wifi on one satellite?
- plemansMar 08, 2022Guru - Experienced User
the newer firmware might help.
You can try downloading it and installing it.
All updated to 4.6.7.13 (odd the router didn't recognise this version via an online update?) - sadly still the same issue
- plemansMar 08, 2022Guru - Experienced Useralways install the satellites first, then the router.
