oOo-MPD-oOo's avatar
Mar 08, 2022
One satellite not relaying guest wifi network (RBR850/RBS850)
Hi   I have a RBR850 orbi router, with two RBS850 satellites connected via a wired connection   One of the satellites has stopped transmitting the guest wifi network, the other satellite and main...
  • oOo-MPD-oOo's avatar
    oOo-MPD-oOo
    Mar 21, 2022
    Definitely something with the switch.   I managed to directly connect the satellites to the router and everything magickly works.   Is this an oddity with this switch or has anyone seen similar behaviour on other switches?
