oOo-MPD-oOo
Mar 08, 2022Tutor
One satellite not relaying guest wifi network (RBR850/RBS850)
Hi I have a RBR850 orbi router, with two RBS850 satellites connected via a wired connection One of the satellites has stopped transmitting the guest wifi network, the other satellite and main...
- Mar 21, 2022
Definitely something with the switch. I managed to directly connect the satellites to the router and everything magickly works. Is this an oddity with this switch or has anyone seen similar behaviour on other switches?
Mar 12, 2022Guru - Experienced User
Possible something else with this model switch that could be causing problems. You might try NGs GS 1 series. These are working for me. GS105/108. Also GS 308v4 is working for me as well.
oOo-MPD-oOo
Mar 21, 2022Tutor
- FURRYe38Mar 21, 2022Guru - Experienced User
Something with the switch. The GS7 series is a managed switch.
Try a GS10x series switch and see.
