bevvet's avatar
bevvet
Ongoing Frequent Disconnect Issue
Anyone here have a Netgear Orbi RBK 852 Unit… I experience seemingly frequent disconnects. Did you ever or do you ever experience this? What did you do to fix it? Im going crazy here. I’ve looked in the connection logs on the Orbi and it doesn’t show any and yet I think something is disconnecting because sometimes sites and apps will take longer to load than other times. Also, streaming loads slower at times. I feel it’s all connected to disconnects. I am noticing it not just with WiFi but Ethernet connections too.
1 Reply
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Does the front LED on the RBR turn on PINK when this happens?
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    MAC Address Randomizers:
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
    Armor, Smart Parental Controls or Circle, Traffic Meter.
