JayB600
Oct 03, 2022Aspirant
Only 1 device(MacBook Air) not connecting to satellite (RBS750)
I am unable to get my MacBook Air to connect to the internet via the RBS750. My MacBook states that the wifi is connected and it’s even listed as attached device to the RBS750 in the admin console, b...
- Oct 09, 2022
I was able to resolve this by resetting BOTH the RBR and RBS - defaulting back to the factory settings, and then using the app to “set up a new orbi system.”
Oct 04, 2022Guru - Experienced User
Have you removed the wifi profile from the Mac Book then while near the RBS, reconnect the device?
Something else to try while at the RBS, set a static/manual IP address ON the mac book, set IP address, Subnet Mask, Gateway and DNS.
What OSX version are you using on the Mac Book?
JayB600
Oct 04, 2022Aspirant
Yeah, I turned off the wi-if + removed the wi-if profile and then turned back on the wi-fi + attempted to connect to the network again. Unfortunately, this did not work.
