JayB600
Oct 04, 2022Aspirant
Only 1 device(MacBook Air) not connecting to satellite (RBS750)
I am unable to get my MacBook Air to connect to the internet via the RBS750. My MacBook states that the wifi is connected and it’s even listed as attached device to the RBS750 in the admin console, b...
- Oct 09, 2022
I was able to resolve this by resetting BOTH the RBR and RBS - defaulting back to the factory settings, and then using the app to “set up a new orbi system.”
Oct 05, 2022Guru - Experienced User
JayB600
Oct 09, 2022Aspirant
- FURRYe38Oct 09, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
