donawalt
Aug 18, 2020Mentor - Experienced User
Only 1 entry shows in log
This is an odd quesiton...my RBR850 router and satellites installation is about a week old, running well...but one odd thing I noticed, I only ever have 1 entry in the log file that shows. Now, the o...
donawalt
Aug 20, 2020Mentor - Experienced User
Interesting. I heard back from Blanca_O and she said they had heard of the problem I reported here from others. Something different in configuration may cause it?
Aug 20, 2020Guru - Experienced User
Anything is possible. Hopefully they can figure it out.
Mines connected to a CM series modem only cable modem. SparkLight ISP.
RBR is in router mode. RBS both ethernet connected behind RBR via GB switches.
Using a 192.168.0.100 to .150 Default DHCP IP address pool.
Auto DNS detect.
CTS 64
20/40Mhz.
No Armor enabled.
Opera Browser.
- donawaltAug 20, 2020Mentor - Experienced User
Here is my config:
Comcast ISP -> CM1200 -> Orbi RBR8500. 2 RBS8500's. No other network hardware - no switches, DHCP servers, etc.
RBR is in router mode (But get this - for the first time, I brought up orbilogin.net, logged in, and as I went to Advanced to see Router/AP Mode, it's grayed out! Have oyu ever seen that?)
All defaults for DHCP address pool, Router acts as DHCP.
CTS 2347 on 2.4 and 5GHz (0 collisions still!)
20/40 MHz
No Armor, no Guest network, UPnP on, IPv6 enabled, no bridges, VPNs, static routes, port forwarding/triggering.
Remote management turned off.
- FURRYe38Aug 20, 2020Guru - Experienced User
Well maybe you have the wrong forum for your RBR8500 and RBS8500. LOL. Kidding.
Haven't see any probems with Router or AP mode:
Have you factory reset your RBR since last update?
What browser are you using for the RBRs web page? I'm use Opera Next.
I don't have IPv6 enabled since my ISP doesn't support it natively.
I have about 30 devices online, wireless phones, wired PCs, wired NAS, 3 wired printers, 4 wireless cameras, DISH Hopper system and 2 wired Joeys and 3 xbox consoles.
FURRYe38 I think I have 15 devices online - printers, laptops, iPad, iPhones, hubs, Apple TVs, TVs.
I have not done a factory reset since the last update. The documentation didn't say I had to, do I? That seems like a lot of work starting over?
I tried Safari and Chrome - grayed out. Seems like some new little thing pops up every other day lol. I have seen your graphic a lot, just stopped being available now. Maybe because I went to LAG today? I bet that is it!
