donawalt
Aug 18, 2020Mentor - Experienced User
Only 1 entry shows in log
This is an odd quesiton...my RBR850 router and satellites installation is about a week old, running well...but one odd thing I noticed, I only ever have 1 entry in the log file that shows. Now, the o...
Aug 20, 2020Guru - Experienced User
Ya your fine.
Thought you might reset the RBR at some point to check for logs, though I didn't reset mine after applying the new v6 FW. I downloaded mine and applied them manually with a wired PC. Wasn't your auto updated?
donawalt
Aug 20, 2020Mentor - Experienced User
Yes I just auto updated firmware, I have never done a manual update of firmware.
- FURRYe38Aug 20, 2020Guru - Experienced User
Maybe one issue causing logs to not display all info. Someting you might try re-loading v6 FW and factory reset to see if changes anything.
- KMDonlonAug 20, 2020VirtuosoThe most recent firmware seemed to fix log entries for me, logs fill up like normal now for since the update. All fixed on my end (so far)
- FURRYe38Aug 21, 2020Guru - Experienced User
Thanks for letting us know. Has been an odd problem.
- Chuck_MAug 21, 2020Mentor
KMDonlon wrote:
The most recent firmware seemed to fix log entries for me, logs fill up like normal now for since the update. All fixed on my end (so far)My logs are still broken. These are only entries after days of uptime:
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:16:40
[Admin login] from source 192.168.1.27, Friday, Aug 21,2020 22:16:40
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:16:05
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:15:30
[DHCP IP: (192.168.1.26)] to MAC address CC:DD:A2:03:FF:46, Friday, Aug 21,2020 22:14:58
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:14:55
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:14:20
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:13:45
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:13:10
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:12:35
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:12:00
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:11:25
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:10:50
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:10:15
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:09:40
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:09:05
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:08:30
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:07:55
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:07:20
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:06:45
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:06:10
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:05:35
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:05:00
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:04:25
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:03:50
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:03:15
[UPnP set event: AddPortMapping] from source 192.168.1.222, Friday, Aug 21,2020 22:02:40
