Paheve
Mar 21, 2021Guide
Open wifi SSID (after upgrade RBR850 to firmware 3.2.17.12_1.4.14)
I hate to say this, but i am very disappointed about the product and the support of our ORBI RBR850 and RBS850 set. There is stil no option to select this set (RBR850) on this support site.... ...
- Mar 23, 2021
I have change the Orbi setup from AP to Router setup.
I connected the satellites with kabel and the sync was taken place.
the open SSID is changed to the secured SSID and all works correctly now.
it seems that in a AP setup, with kabel connected to the satellites, gives some synchronization bugs or give unexpected behaviors.
Mar 21, 2021Guru - Experienced User
Try a factory reset on the RBR and RBS.
Make sure RBS is updated first then RBR lastly with same FW versions.
