Paheve
Mar 21, 2021Guide
Open wifi SSID (after upgrade RBR850 to firmware 3.2.17.12_1.4.14)
I hate to say this, but i am very disappointed about the product and the support of our ORBI RBR850 and RBS850 set. There is stil no option to select this set (RBR850) on this support site.... ...
- Mar 23, 2021
I have change the Orbi setup from AP to Router setup.
I connected the satellites with kabel and the sync was taken place.
the open SSID is changed to the secured SSID and all works correctly now.
it seems that in a AP setup, with kabel connected to the satellites, gives some synchronization bugs or give unexpected behaviors.
Mar 21, 2021Guru - Experienced User
Ensure the RBS are updated using same version of FW as the RBR.
Pleaase factory reset the RBR and RBS and setup from scratch. Setup the RBR first and ensure you set WPA2 and AES Only. Then wirelessly sync the RBS one at a time to the RBR.
If this still fails for you, please contact NG support for additional help and information. You may have a faulty system.
fangruoyuan wrote:
try to chanage the 2.4g and 5g channel(the one is open network) and wait for its reboot.As i mentioned one year ago,this is a bug in the firmware,it even exists after a year.
Paheve
Mar 22, 2021Guide
I try all the steps described above. Sadly there is no change.
what I find out is that te Router sends the correct SSID.
when 1 of the 2 satellites is started the SSID is changed to open.
I have try to sync the satellites with and without kabel, various factory resets are done.
still same the issue. So if someone has a good idee...
I am almost on the point to sell this non working WiFi solution!!!
- fangruoyuanMar 23, 2021Guide
Try to change country,then check
I think you are runing RBR 850 as ap mode or at least the satellites are wired to RBR850, the open ssid happened many times last year for me.
- PaheveMar 23, 2021Guide
That's correct, the setup is based on AP with kabels connected.
Good to hear that I am not the only one with this issue.
so now I need to know what is the solution for this...
