minetworking
May 13, 2020Aspirant
Optimizing for the best wifi 6 mesh setup
Hi there, We are moving in to a 3,000 sq ft house that's fully wired with Cat6 and have AT&T fiber 1GB. As a result, I'm trying to determine what the best wifi 6 mesh system is to purchase? ...
May 13, 2020Guru - Experienced User
https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-and-Cable-Modem/m-p/1864698#M21950
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Review the spec sheets for the 850 and 750 series. I believe the main differences are the connections rates seen on the wifi radios.
https://www.netgear.com/support/
- minetworkingMay 13, 2020Aspirant
Thank you for your prompt reply. It seems AT&T modem can be configured for passthrough (https://forums.att.com/conversations/att-internet-equipment/strict-nat-bridge-mode-what-is-ip-passthrough-can-i-enable-on-my-arris-bgw210-or-like-router/5defbfffbad5f2f606ad5ed2)
*If* this is the case, what do you recommend betweent he 750 and 850? Is it worth paying up for the 850 if the wired connection points will be the same speed?
- FURRYe38May 13, 2020Guru - Experienced User
I don't have any experience with 7 series AX System. I presume it should compare well to the 8 series system. Something you could get from a retailer that have a good refund policy and try it out. If it doesn't work to your liking, return it and get a refund.
