agaurav
May 19, 2021Aspirant
Optimizing performance when used with AT&T Arris BGW210-7000
I have an Orbi 6 router. The model is actually RBR850 (not RBR50). Firmware version is V3.2.18.1_1.4.14. I have connected it to my AT&T Fiber 1gbps service via Ethernet port into the Arris BGW210-700...
May 25, 2021Guru - Experienced User
Any progress on this?
Even though Orbi is in the IP Pass thru section of your ISP modem/router, it should be getting most of it's traffic thru the IP pass thru feature and not being routed by the modems router portion. You are in a double NAT condition, however IP Pass Thru will work in this condition when connected to a router or gateway modem with a built in router infront of the RBR.
- agauravMay 25, 2021Aspirant
I gave up. There is far too many parameters and I don't see what else I can do or try. I setup the AT&T Arris gateway in IP passthru mode. Internet works on my wireless devices connected to the Orbi 6.
I get high bandwidth of 300-500 mbps but sometimes my kids will say that scrolling on some apps is slow on their phones. I have no idea why. I figured maybe the DNS is an issue because on my windows laptop I often get dns_probe_finished_nxdomain problem for 1-2 seconds and the page loads automatically. But who knows what is going on.
I have no more inputs/parameters to make further progress or debug/triage the problem.
- FURRYe38May 25, 2021Guru - Experienced User
What happens if you remove the IP pass thru on the modem and configure the RBR for AP mode?
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Be sure that Traffic Meter is disable on the RBR.
I haven't tried that yet and will try that this weekend.
