volodia
Aug 22, 2022Aspirant
Option Orange DHCP dans RBR750
Bonjour,
Je ne trouve pas dans mon RBR750 l'option pour activer l'accès direct à la fibre Orange DHCP via l'ONT.
Dans le code de la page, l'option est commentée.
La fonctionnalité a-t-elle...
ekhalil
Aug 22, 2022Master
Do you have Parental Control activated in the RBR750? I think that Netgear Parental Control uses an own DNS and will block your ability to choose DNS.
- volodiaAug 22, 2022Aspirant
Hi ekhalil,
No, it is straight out of the box.
The issue is not with DNS but with the ability to use some options in the "ISP requires login" functionality.
There is PPPOE and other standard options, but the two "Orange" options are not available.
Thanks
- ekhalilAug 22, 2022Master
Can you please explain what "two Orange Options" do you mean?
For connecting to Orange network in France, using only the ONT, there is apparently the option in Orbi systems for configuration using PPPOE or DHCP (See attached picture). It is reference in multiple posts on this forum.
It is not available on mine.
