Towny
Dec 23, 2023Aspirant
Or I AX6000 Tri-band mesh WiFi 6 router RBR850. Keeps losing the connection to the satellite Orbi.
I live in an old granary where the walls are very thick, and so I purchased a Orbi RBR850 with two satellites, which seem to work at first, but now all seems to keep disconnecting from the satellites...
CrimpOn
Dec 23, 2023Guru - Experienced User
How do you manage the system? (web browser or Orbi 'app'?
Both display the current firmware version.
Do the satellite reconnect automatically, or do you have to restart the system?
Towny
Hi
i have looked on the app and it says the Firmware version is V4.6.14.3, also tried a update and it says it is up to date. It tense to rectify itself, but on occasions, I have to reset the whole system.
I have done a back to factory settings and a reboot.
Thanks
- FURRYe38Dec 23, 2023Guru - Experienced User
v7 is most current. Some may not see this in the Auto Updater so you'll need to manually update the RBS first then RBR lastly"
