Towny
Dec 23, 2023Aspirant
Or I AX6000 Tri-band mesh WiFi 6 router RBR850. Keeps losing the connection to the satellite Orbi.
I live in an old granary where the walls are very thick, and so I purchased a Orbi RBR850 with two satellites, which seem to work at first, but now all seems to keep disconnecting from the satellites...
Towny
Hi
i have looked on the app and it says the Firmware version is V4.6.14.3, also tried a update and it says it is up to date. It tense to rectify itself, but on occasions, I have to reset the whole system.
I have done a back to factory settings and a reboot.
Thanks
Dec 23, 2023Guru - Experienced User
v7 is most current. Some may not see this in the Auto Updater so you'll need to manually update the RBS first then RBR lastly"
