Applefan62
Aug 22, 2022Follower
ORB RBR750 in combination with UBEE UBC1318ZG modem resulted in wireless speed decrease
Hi, I recently switched to new ISP contract 1Gbit download/50Mbit upload. With this change also the modem is exchanged by a UBEE UBC1318ZG modem. This modem is configured in bridge mode. After ...
Aug 22, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Are you speed testing with a wired ethernet PC?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Please edit out any MAC Addresses or Product serial numbers before posting in public forums for security reasons.
There is newer FW available for your system:
