hnz980
Jul 26, 2021Tutor
Orbi - RBR850 -WAN Port speed problems to Arris S33 - Surfboard DOCSIS 3.1 Cable Modem
Hello, My Oribi Wifi 6 router is connecting at 100 mbps speeds to my Arris S33 DOCSIS 3.1 Cable Modem. I am using the Cat 5E cables that were supplied. My provider is Xfinity/Comcast and I...
hnz980
Jul 26, 2021Tutor
I have not tried cat 6 cable. I will give that a go.
When I do a hard wire directly to the S33 from my mac m1 with the Netgear supplied gig 5e. I get gigE speeds.
Jul 26, 2021Guru - Experienced User
Some cat 5e (cheaper ones) have been sketchy at best. I've had them with gig speeds for certain devices and not for others.
Its usually why I'd recommend trying a different cable first.
Also, look at the port on the router. Maybe a pin is bent or dirty causing it to limit to only 10/100mbps connections links
- hnz980Jul 29, 2021Tutor
I powered down the Arris and powered down the Orbi and disconnected all the cables.
I started up the Arris and Orbi and the Arris registered blue then I plugged the cat 8 cable into the wan port on the Orbi.
I did a test and I am still getting 100M/Full. The statistics show the WAN PORT at 100M/Full on the Advanced tab.
- FURRYe38Jul 29, 2021Guru - Experienced User
I would get into a diffeent modem. This Arris S33 seems to be problematic at best. Seen others having problem with the model modem. My 850 connect fine to a NG CM1200 modem at 1000Mbs. Also connects to a CAX80 at 2.5Gb as well.
- plemansJul 29, 2021Guru - Experienced UserAre you plugging into the 2.5g or the 1 gig port on the s33? Did you try then both?
