przemek3d
Sep 09, 2022Aspirant
Orbi - unstable connection, no event logs
My Orbi system is unstable, the wifi disconnects often. I am getting many unstable connection notifications while having video calls. As a side note, I do not see any event logs. I saw them after I...
Sep 09, 2022Guru - Experienced User
What Orbi model do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- przemek3dSep 14, 2022Aspirant
Hi FURRYe38, thanks for your help:
What Orbi model do you have? CBR750
What Firmware version is currently loaded? V4.6.5.8_2.0.54
What is the size of your home? Sq Ft? 3500
What is the distance between the router and satellite(s)? 30 feet or more, might be less than 30 feet in a straight line, but they are on separate floors, separated by walls - I can move it furtherWhat channels are you using? Auto and 48 on 5Ghz
I did not answer the question about the modem router connection as this is one device. After I restarted the main router I saw the event logs for a day. Then they stopped appearing. There are also issues with NTP Settings. As I mentioned, the wifi connection becomes unstable - I need to manually switch between the primary and guest network, as one of them becomes unusable. Not sure if all of the above issues are related.
- FURRYe38Sep 15, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page. Use a different browser if needed.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-routerHave the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.htmlTry using channels 1 and 40.
Try setting the transmit power to 50% on the CBR. Under Advanced Tab/Advanced Settings/Wireless Settings
- przemek3dSep 18, 2022Aspirant
Thanks for the help. I changed the channels to 1 and 40 and reduced the power to 50%. After reading the article, I noticed that one of the upstream channels might be problematic:
6 Locked ATDMA 6 2560 Ksym/sec 40400000 Hz 49.8 dBmV I also noticed quite often the following critical event.
Sep 16 2022 22:08:07 Critical (3) No Ranging Response received - T3 time-out I hope this is not an issue with my home wirings, as that would be hard to detect. There were multiple Comcast technicians checking my wirings and signal coming to the modem. They said it was ok.
I'm attaching the cable connection (sorry for the format, it is hard to attach something readable here) to the post and pasting event logs below (they were usually missing):
Time Priority Description
Sep 16 2022 12:53:14 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 16 2022 13:06:58 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Sep 16 2022 13:06:59 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 16 2022 13:26:56 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Sep 16 2022 13:27:01 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 16 2022 13:32:56 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Sep 16 2022 13:33:18 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 16 2022 13:38:55 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Sep 16 2022 13:38:58 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 16 2022 13:48:54 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Sep 16 2022 13:48:55 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 16 2022 22:46:25 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 17 2022 00:07:42 Alert (2) CM Certificate Error
Sep 17 2022 00:10:23 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 17 2022 11:39:08 Critical (3) No Ranging Response received - T3 time-out
Sep 17 2022 11:41:16 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 17 2022 13:23:18 Critical (3) No Ranging Response received - T3 time-out
Sep 17 2022 13:35:56 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 17 2022 22:03:28 Critical (3) No Ranging Response received - T3 time-out
Sep 17 2022 22:11:48 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 18 2022 00:07:41 Alert (2) CM Certificate Error
Sep 18 2022 00:08:17 Notice (6) CM-STATUS message sent. Event Type Code: 5
Time Not Established Critical (3) No Ranging Response received - T3 time-out
Sep 18 2022 07:48:37 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Sep 18 2022 07:48:37 Notice (6) TLV-11 - unrecognized OID
Sep 18 2022 07:48:37 Critical (3) Config File Rejected due to Invalid or Unexpected TLV 11
Sep 18 2022 07:48:42 Warning (5) REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value
Sep 18 2022 07:48:42 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW
Sep 18 2022 07:48:42 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Sep 18 2022 07:48:53 Alert (2) CM Certificate Error
Sep 18 2022 09:07:40 Notice (6) CM-STATUS message sent. Event Type Code: 5
Sep 18 2022 14:27:41 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Sep 18 2022 14:27:41 Notice (6) TLV-11 - unrecognized OID
Sep 18 2022 14:27:41 Critical (3) Config File Rejected due to Invalid or Unexpected TLV 11
Sep 18 2022 14:27:45 Warning (5) REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value
Sep 18 2022 14:27:45 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW
Sep 18 2022 14:27:46 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Sep 18 2022 14:27:56 Alert (2) CM Certificate Error
Sep 18 2022 14:37:46 Notice (6) CM-STATUS message sent. Event Type Code: 5
