physast
Oct 03, 2021Guide
Orbi + August lock (WiFi) = disconnect/reconnects
It was suggested that I post about this problem in this forum. I have a CBR750 with one satelite mesh system on a 1GB cable internet. I have about 20 devices connected. My issue is that my august...
physast
Oct 03, 2021Guide
FURRYe38 Thank you for replying and these suggestions.
- House is 1600 sqft
- Feet between router and satelite is about 25 feet (plaster board walls, older house)
- 2.4Ghz is on channel 6 and 5Ghz is set to 48
- Many Wifi neighbors, about 7
Armor is disabled, or not on because I don't have a subscription. I have not tried disabling IPv6 yet but will and report back. Will also try the other settings as well.
I am also seeing disconnects now on other smart devices, Ring alarm being one and my VOIP phone.
Sometimes when I log into the orber app I notice that some devices are not connected, but I would think they should be. For instance the August locks, Ring doorbell and some smart lights. Should they all always show connected? Is it normal to see some devices not connected?
Oct 04, 2021Guru - Experienced User
What happens if you move the RBS out a bit farther? Say 35 feet?
Try setting CTS to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings.
- physastOct 04, 2021Guide
I have moved the main router and turned off the satelite. I will wait a few days and see if this helps at all. I am starting a list of other things to try, so thanks for all the suggestions.
I have noticed another SSID showing up with a very strong signal when searching for WiFi networks. My SSID and also a NETGEAR79. Is it possible that this is also being broadcast from my Orbi Router? How do I find out? Is this normal?
- FURRYe38Oct 05, 2021Guru - Experienced User
So you have NETGEAR79 as a SSID name? Change it to something else. Something unique and different. Then look to see how it shows up.
