corona247
Aug 31, 2020Aspirant
orbi + RAX 120
RAX 120
Hello all, newbie here:
Currently have a AX 120 as our house wifi. Just got orbi premium RBK 752. Planning on setting the orbi router as an AP using the wired ethernet wall connections I have in the house.
I read that I could maybe setup up WAN aggregation with the orbi and AX120 as that could provide faster connection speeds. Correct? and if so, can someonw provide an overview of the steps involved to setup.
If aggregation not advisavble, i was just going to follow given instructions per orbi to setup up the orbi's as AP.
Any thoughts, advice, recommendations much appreciated
1 Reply
LAG is not supported in AP mode on the Orbi AX, only in router mode. Mainly meant for the RBR connected to a LAG supporting modem, i.e. CM1100, 1200 or CAX80.
