Siriole
Jan 27, 2020Guide
ORBI + SAMSUNG TV + BT
After a factory re-boot recommended by on-line support, the problems disappeared only to return within a day or two, just as they had done before. They relate specifically—very specifically–to what a...
- Feb 13, 2020
Zzio got in touch after my last (rather grumpy) message with some beta upgrades to the software. I downloaded and the Orbi system worked immediately. I waited three days, during which I tested all the apps systematically, and I am happy (ecstatic!) to report that it is working well, indeed incredibly well. So there you have it, after a month and maybe thirty hours of fault-finding, it works. Early adoption is often quite difficult, but not THIS difficult.
So thanks to ZZio for persisting when I did not. And thanks to all the others who contributed suggestions and support. The Community has been a great resource (technical and emotional).
It's difficult to be gracious about Netgear. Why the tech support team in India didn't seem to have the beta upgrade, I can't fathom. Ironically they asked me for a copy of V3.2.10.1. This has led me to question whether Netgear supports them appropriately.
Thanks to all who helped.
Siriole
Feb 10, 2020Guide
In the event the firmware 'upgrade' was a downgrade to V3.2.8.5.
We tested the television system before the change and after the change. Nothing was different; exacly the same problems were evident: Can't upload Amazon Prime, can load Apple TV but it takes forever to download a movie from my library (or any other movie for that matter). Other applications work (Netflix, Curzon Cinema, iPlayer (BBC)--but slowly, Netflix).
I've decided to 'throw in the towel' and seek a refund from my devices. I think I have acted in good faith to get the devices work--the product doesn't seem ready for market.
Thanks folks out there for all your interest and advice. I've spent a month working hard on a remedy for this. I am going to return to my cheap ISP's router and forgo extraordinary wireless performance for the sake of having a good internet connection.
Feb 10, 2020Guru - Experienced User
Would have been intereseting to see if the FW that zzio got from NG support would have solved this issue.
Oh well. We understand.
Good Luck.
- SirioleFeb 13, 2020Guide
- FURRYe38Feb 13, 2020Guru - Experienced User
Well well, I guess at least someone did help you out. You might try and contact NG again next time anything like this happens to see if a beta can be made avaialble. Depending upon problem. :smileyfrustrated:
Shouldn't be posting beta FW updates in forums, what may work for others may break something else for another. However, hopefully it makes things better for all.
Enjoy now. :smileywink: - fraczek12345Feb 16, 2020Aspirant
Thanks for this beta firmware!!! It has fixed all my problems, finally :)
- SirioleFeb 16, 2020Guide
Glad this has worked for you, but It's Zzio who we should be thanking!
True :) Thanks Zzio! :D
- fraczek12345Feb 16, 2020AspirantI see only one problem: I have 1 router and 4 satellites. 3 satellites are connected by the cable directly to the Orbi router and 4th one is connected to the switch (which is connected to the Orbi router). When I move around the house I only have problem with the one satellite that’s connected to the switch - my iPhone disconnects sometimes. So my question is: should all 4 satellites be connected to Orbi router directly or all should all 4 be plugged in to switch and then to Orbi router? Or it’s not a problem and some of them can be plugged in to router and some to switch?:)
- FURRYe38Feb 17, 2020Guru - Experienced User
Direct wold be preferred.
What is the Mfr and model# of this swtich? There are known issues with Orbi and some swtiches...
