abelloni
Sep 09, 2021Aspirant
ORBI 350 BAD Internet from LAN Ports
Hello I purchased a RBR350 plus Satellite RBS350 I followed the instruction for substituting the Vodafone Router (FTTH with Fiber to ethernet converter) and configuring the RBR350 according t...
- Sep 09, 2021
Have you powered OFF The RBR by pulling the power adapters from the wall socket for 1 minute then plug back in?
If you have or any of this doesn't help to fix, I would return it to place of purchace. I recommend letting the seller know that the unit needs to be returned to NG as the HW is bad.
Sep 09, 2021Guru - Experienced User
