abelloni's avatar
abelloni
ORBI 350 BAD Internet from LAN Ports
Hello   I purchased a RBR350 plus Satellite RBS350   I followed the instruction for substituting the Vodafone Router (FTTH with Fiber to ethernet converter) and configuring the RBR350 according t...
  • FURRYe38's avatar
    Sep 09, 2021
    Have you powered OFF The RBR by pulling the power adapters from the wall socket for 1 minute then plug back in?
    If you have or any of this doesn't help to fix, I would return it to place of purchace. I recommend letting the seller know that the unit needs to be returned to NG as the HW is bad.
