TherJ
Nov 27, 2021Aspirant
Orbi 350: Wired connection cannot access internet. Wifi works
I have an Orbi RBR 350. The wifi works well however, the wired connections do not work. When I connect a laptop via ethernet to the router, it shows up as 'connected to the internet via ethernet...
Nov 27, 2021Guru - Experienced User
And both laptops have there networking settings set for obtain IP addressing automatically?
Do these laptops work ok with being wireless?
Be sure to swap LAN cables with a good working cable. CAT6 is commended.
- TherJNov 27, 2021AspirantIP assignment = automatic (DHCP)
Laptops work fine when using wireless connection to router
I can ping sites via Ethernet. No dataloss.
Swapped cables.
