TherJ
Nov 27, 2021Aspirant
Orbi 350: Wired connection cannot access internet. Wifi works
I have an Orbi RBR 350. The wifi works well however, the wired connections do not work. When I connect a laptop via ethernet to the router, it shows up as 'connected to the internet via ethernet...
TherJ
IP assignment = automatic (DHCP)
Laptops work fine when using wireless connection to router
I can ping sites via Ethernet. No dataloss.
Swapped cables.
Swapped cables.
TherJ
Data cables are Cat 5e
- TherJNov 27, 2021Aspirant
I tried a different router and the wired connection works fine so it must be an issue with the Orbi router.
- FURRYe38Nov 28, 2021Guru - Experienced User
I commend you contact NG support and ask for help and information regarding this. Ask about an RMA. Seems that the RBR maybe faulty and needs replaced. Seems to be a known issue. Work around for now is to use AP mode with a different router.
