MarkyMark59's avatar
MarkyMark59
Follower
Apr 09, 2022
Orbi 352 or 752 for 500Mb download speed
Hi, I'm in the UK and just about to be connected to Virgin Cable at 500Mb. I want to invest in a Mesh system for my three story house but i'm unsure weather  the RBK 352 (AX1800) will do or should I...
  • plemans's avatar
    Apr 09, 2022
    I'm a fan of the triband mesh systems versus dual. the dedicated backhaul between router---satellites gives you much faster speeds, lower latency, and tends to be more stable. And with 500mbps speeds, its better to have to much performance versus not enough.
    the only time I really recommend the dual bands, is if its for someone that plans on hardwiring in their satellites. Then its better to go dual as the 3rd band is only for the backhaul.
