eskridgeb
Oct 30, 2021Follower
Orbi 4.6.3.16 Firmware blocks apple servers
I have an ORBI RBK852 system and it recently auto-updated to firmware 4.6.3.16. After this update, I have been unable to connect to any of the Apple services/servers - preventing the Find My network...
Oct 31, 2021Guru - Experienced User
What modem/gateway is it connected to?
Are you using IPv6?
Have you tried a different DNS provider? You can try googles at 8.8.8.8 or 8.8.4.4
If there's an issue after a firmware upgrade, one of the first things I try is a factory reset. Sometimes old settings can cause issues.
