Seeker2024
May 06, 2024Aspirant
ORBI 42 RBR350, D-Link DSL-X1852E connected to VOIP phone. Need ORBI to boost Wi-Fi to living area.
Windows 10 Home Version 10.0.19045 Build 19045 ISP provided Modem/Router D-Link DSL-X1852E, does ADSL, VDSL, Fiber. It is attached to Fiber ONT box, controls VOIP phone. Wi-Fi.signal insufficient to...
- May 09, 2024
Let us know how it all turns out.
Good luck.
Seeker2024
May 08, 2024Aspirant
Hi, Sorry for slowness in response. Have to work around others' needs with either access to internet or access to phone.
I think you have provided the information I need. The last hurdle - I think ISP has special arrangement with fibre support company as to what is coming through the ONT box.
I now need to contact them to see if it is possible to change back to same setting at our address as we had in the past with all our other ISPs. (not us changing them, but other companies amalgamating or being bought out by bigger fish)..
Once I am sure, I can set the ORBIs up as your per your solutions - YouTube excellent, restart everything, plug in the phone and hopefully be fully functional again.
I have learned a lot from you regardless. Thank you!
May 09, 2024Guru - Experienced User
Good luck.
- Seeker2024May 14, 2024Aspirant
Took a while -fighting with trying to get OneDrive off my system - Sorry for the delay. All good. Others will also find this very helpful.
Thanks!
- FURRYe38May 15, 2024Guru - Experienced User
Enjoy. 📡
