dbcyclist
Jun 09, 2024Follower
Orbi 6 and upgrade from DSL to Gigabit Fiber
I have an Orbi 6 AX4200 Base with 2 Satellites that are hard wired to the base station. Recently we were able to upgrade from our old DSL connection to Gigabit Fiber. The fiber terminal (ONT) i...
- Jun 09, 2024
If it ain't broke, don't "fix it." Yes, the Orbi must be in 'router mode'.
Jun 09, 2024Guru - Experienced User
Most wifi devices may not see anything near 900Mpbs due to there design and support limiations. Especially 2x2 MIMO devices. 4x4 MIMO can see near that and over. IF your seeing that with your devices and this system, you good.
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.wiisfi.com
https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi
Too Much Wifi: https://youtu.be/UR0viMLISz4
Try a power cycle of the system OFF for 1 minute then back on before a factory reset.
