nxda
Jan 09, 2020Aspirant
Orbi 6 AX6000 - How many satellites - Wired Backhaul possible?
Although I have seen it written in different forums that the latest Orbi 6 is expandable with the ability to add additional satellites and that the satellites can use a wired backhaul... I have yet t...
Chuck_M
Jan 10, 2020Mentor
What you have described is pretty much my scenario. Very long home with outbuildings.
I have an AX6000 connected to a netgear switch. From the switch I have three satellites (one RBS853 and two RBS 50s)
RBS50s are hardwired
I will swap the RBS 50s for 853s when they are sold separately.
Bottom line: Works like a champ.
DoctorA
Jan 10, 2020Luminary
Except WiFi 6, do you see any performance advantages using 850 satellites instead of RBS 50s?
My iPhone XsMax has slightly faster internet speed connected to RBS 850. But I am not sure about the longer range.
- Chuck_MJan 10, 2020Mentor
The wireless backhaul is extremely fast for the RBS 853s. Also, the radios are far stronger and cover a much larger area than the old RBS50s.
I will definitely swap them out when the new ones are available separately.
Specificially I noticed things like stronger signals on Nest doorbells and other IOT devices.
