Keithboi
Oct 24, 2021Tutor
orbi 6 mesh wifi connecting to 2 modems
hello,can i set up 2 wifi6 orbi systems i same building,each has its own fibre modem,2 separate lines coming in.the owner insists on having one network for her work and one for guests.and just using ...
- Nov 12, 2021
You can try the app, under Settings, not sure if you can change the mode there, if no, you can on the web page.
Oct 25, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Orbi AX supports the main wifi network and a guest network as well if the one system "the owner insists on having one network for her work and one for guests"
Thank you
Keithboi wrote:
hello,can i set up 2 wifi6 orbi systems i same building,each has its own fibre modem,2 separate lines coming in.the owner insists on having one network for her work and one for guests.and just using guest network of one system is not acceptable.ive already bought 2 x rbk755 systems.please HELP
keithboi
