Keithboi
Oct 24, 2021Tutor
orbi 6 mesh wifi connecting to 2 modems
hello,can i set up 2 wifi6 orbi systems i same building,each has its own fibre modem,2 separate lines coming in.the owner insists on having one network for her work and one for guests.and just using ...
- Nov 12, 2021
You can try the app, under Settings, not sure if you can change the mode there, if no, you can on the web page.
Oct 24, 2021Guru - Experienced User
Yes you can do this.
Just set them with a different ssid and channel.
not a big deal.
Next time, I'd push for switching to a business class like the SXK80 where you can seperate out ssid's and only have to pay for the one modem/isp connection.
Keithboi
Nov 02, 2021Tutor
client insists on having a personal line and modem as a cuople of years ago a rental in the villa downloaded some pretty undesireble stuff and the owner got blocked by google and took an awful lot of hassle with the lawers to get access returned.this is why i have to have to lines.thx for your advice,K
- FURRYe38Nov 02, 2021Guru - Experienced User
:smileyfrustrated: Good Luck man.
- KeithboiNov 12, 2021Tutor
Hi, well ive installed first RBR with 4 RBS and works magnificently,986 mbps,down and 842mbps up. i then turned everything off and installed second system on second isp modem and i thought all was going superbly ,same up and down speeds, BUT when i tried to load Netflix and other apps i couldnt connect!!when i looked into things it became apparent that the sec protocol is WPA28-PSK(AES),now i looked into changing the settings but did not see this option. HUH!! Is there anyway of accessing somewhere in the interface so i can change the orbi s settings because i cant change the isp modems settings,
thans for all your help,keith
- FURRYe38Nov 12, 2021Guru - Experienced User
Security settings for wifi is under Basic Tab/Wireless settings.
WPA2 and AES should work well...
