Keithboi's avatar
Oct 24, 2021
orbi 6 mesh wifi connecting to 2 modems
hello,can i set up 2 wifi6 orbi systems i same building,each has its own fibre modem,2 separate lines coming in.the owner insists on having one network for her work and one for guests.and just using ...
  • FURRYe38's avatar
    You can try the app, under Settings, not sure if you can change the mode there, if no, you can on the web page.
