Keithboi
Oct 24, 2021Tutor
orbi 6 mesh wifi connecting to 2 modems
hello,can i set up 2 wifi6 orbi systems i same building,each has its own fibre modem,2 separate lines coming in.the owner insists on having one network for her work and one for guests.and just using ...
- Nov 12, 2021
You can try the app, under Settings, not sure if you can change the mode there, if no, you can on the web page.
Oct 24, 2021Guru - Experienced User
Yes you can do this.
Just set them with a different ssid and channel.
not a big deal.
Next time, I'd push for switching to a business class like the SXK80 where you can seperate out ssid's and only have to pay for the one modem/isp connection.
Keithboi
Nov 16, 2021Tutor
All good,thanks for your advice,K
plemans wrote:Yes you can do this.
not a big deal.
- FURRYe38Nov 17, 2021Guru - Experienced User
So after you got the system up and running, just curious, what firmware version are the two systems running?
- KeithboiNov 22, 2021Tutor
firmware version V4.6.5.14 and a week later its still working like a dream,no gremlins yet
- FURRYe38Nov 23, 2021Guru - Experienced User
Glad it's all working.
Enjoy. :smileywink:
