Keithboi
Oct 24, 2021Tutor
orbi 6 mesh wifi connecting to 2 modems
hello,can i set up 2 wifi6 orbi systems i same building,each has its own fibre modem,2 separate lines coming in.the owner insists on having one network for her work and one for guests.and just using ...
- Nov 12, 2021
You can try the app, under Settings, not sure if you can change the mode there, if no, you can on the web page.
Keithboi
Nov 16, 2021Tutor
All good,thanks for your advice,K
plemans wrote:Yes you can do this.
Just set them with a different ssid and channel.
not a big deal.
Next time, I'd push for switching to a business class like the SXK80 where you can seperate out ssid's and only have to pay for the one modem/isp connection.
Nov 17, 2021Guru - Experienced User
So after you got the system up and running, just curious, what firmware version are the two systems running?
- KeithboiNov 22, 2021Tutor
firmware version V4.6.5.14 and a week later its still working like a dream,no gremlins yet
- FURRYe38Nov 23, 2021Guru - Experienced User
Glad it's all working.
Enjoy. :smileywink:
