MinionTA
Sep 29, 2021Aspirant
Orbi 6 RBR850 SSID issue (Please Help!)
I purchased an Orbi RBR850 in March of this year. It was amazing. In June it started acting very sketchy and some random wifi devices (alexa/cameras) stoped working. The guest wifi which is only us...
Sep 30, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Circle, Traffic Meter, IPv6 and
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Under Advanced Tab/Advanced Settings/Wireless Settings
Do you have devices connected to Guest Network all the time?
- MinionTASep 30, 2021Aspirant
Current Firmware = v4.6.3.16
Netgear CM2050V Modem
3200 Sq ft - 2 level home
Satilite is on floor 1, Router is on Floor 2. I would estimate roughty 25-30 ft apart with a floor between.
It is on auto for channel. I can certainly try a channel suggested.
I have 2 neighbors but they do not have wifi. I have a neibor across the street that does have wifi and appears weak in my home.
Traffic, Circle, Armor, and Ip6 are disabled already.
I do not understand the coexistence/CTS part but I can certainly change that if it could help.
I do have devices connected to guest at all times. I am guessing it is usually 5-9 devices on guest and the remaining 60+ were on the main SSID.
The most recent factory reset was done a few days ago. I do not know if a firmware update has been completed since the factory reset before that.
- FURRYe38Sep 30, 2021Guru - Experienced User
Satilite is on floor 1, Router is on Floor 2. I would estimate roughty 25-30 ft apart with a floor between. I would try moving the RBS a bit farther out.
I do not understand the coexistence/CTS part but I can certainly change that if it could help. Please try the sugggestions.
I do have devices connected to guest at all times. I am guessing it is usually 5-9 devices on guest and the remaining 60+ were on the main SSID. Are you 60+ devices spread out connected across the RBR and the RBS or are they all connected at the RBR?
