flopgon
Dec 29, 2021Follower
Orbi 6 Seguridad o Armor
Hola a todos! Compre mi Orbi Mesh de Wifi6 de segunda mando por Amazon, cuando lo recibi lo probe cambie la contraseña y lo registre a mi nombre con la factura de amazon de compra y esta el modelo re...
Dec 29, 2021Guru - Experienced User
You would need to contact support for that.
To get a hold of support for subscriptions services like Armor/Circle, click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process.
Click on: My Support---->Contact Support---->Get help with my subscription service
If that doesn't help, theres an email in the FAQ for registration site you can contact.
