sjm1967
Jul 09, 2021Aspirant
Orbi 6
hello, i purchased 2 x orbi packs and 2 seperate orbis so i could have a total of 6
with only using 1 router
the 2 units with the pack connect ok and the 2 extra units connect ok but it transpires the 2 units in the other pack are tied down to their router
how do we default / reset the two units so they will connect to a different router
i have tried all the usual factory defaults and nothing seems to work
many thanks
scott
many thanks
scott
1 Reply
Remove the 2nd RBR.
Ensure the primary RBR and ALL RBS are using same version of FW.
Press the sync button on the RBS then RBR to sync 1 RBS at a time to the RBR. Wait for the front LED to turn BLUE before turn it off and syncing the next RBS.
