denbee
Aug 25, 2022Follower
ORBI 6000 satellite now showing up. Can't update Satellite Firmware & use ethernet
I am getting blazing wifi speeds with my new ORBI 6000. I updated to the latest firmware on the base station. However, the satellite does not show up on the computer software. It says disconnected...
Aug 26, 2022Guru - Experienced User
Power off the RBS and put it out at 30 feet or more. 25ft is too close to the RBR.
Might need to bring to the same room and the RBR and re-sync it.
Remove the RBS entry on the RBRs web page by selecting REMOVE. Then press the sync button on the RBS then on the RBR. Give it 5 minutes for it to sync and connect.
