Will307
Dec 19, 2022Tutor
Orbi 6E Brand New slow Web?
I have ~140 devices on my Orbi. Subnet is 255.255.255.0 so all devices are of the form 192.168.1.* The Web Interface is dog slow? What gives? It took me 30 minutes to setup Reserved Addresses f...
Dec 19, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What browser are you using? Happens with other browsers?
Try a different PC to compare?
Wire or wireless connection with the UI?
Wow that many devices. Wheew...maybe bogging down the UI...
Will307
Dec 20, 2022Tutor
Hardware Version RBRE960
Firmware Version V6.3.7.5_3.2.25
Just bought Orbi a couple weeks ago so this has to be newest (I hope). Some devices did not re-connect -- I'm up to 145 devices now all on 192.168.1.* 255.255.255.*
I'm using the Cable that came with my new Orbi to connect my modem to NG. Is this one good enough? I have some extra (gold) ones I could replace it with -- but I figured I would just use the one that came in the box.
The model -- well -- right now I'm not sure but I will check.
The App behaves fine by the way with showing all the devices I have -- its just the web that is dog slow.
- Will307Dec 20, 2022Tutor
Also.....I got the 3 device 6E (black edition not that this matters :). So, 1 Router and 2 Sat
- FURRYe38Dec 20, 2022Guru - Experienced User
Chrome and Firefox both behave the same slow way.
Wireless connection.
Only from one machine so far (laptop) I can try another
- FURRYe38Dec 21, 2022Guru - Experienced User
Have you tried newer version of FW?
Does same thing happen with this version?
Firmware Version V6.3.7.5_3.2.25Just bought Orbi a couple weeks ago so this has to be newest (I hope). Some devices did not re-connect -- I'm up to 145 devices now all on 192.168.1.* 255.255.255.*
