Caprice24
May 13, 2022Tutor
Orbi 6e cannot connect to Starlink
Well I wasn't able to get the Orbi 960 to get an Internet connection with Starlink V2, using the Starlink Ethernet adapter, so have filed a trouble ticket with Netgear. The unit is getting an IP addr...
- Jun 10, 2022I just purchased the orbi 6e and tried to get ot to work with my starlink gen2 and had the same exact issue. After spending three nights on the phone with netgear tech support for 3-4 hours each time and them escalating it then escalating it again to their engineering department I was given no time frame for a fix. After much research online and trying everything I could find I decided to try a netgear gs108t switch. I plugged the switch in directly from the starlink ethernet adapter then the orbi 6e into that and it works perfect. Netgear definitely has an issue with the orbi working with starlink directly but this was the only work around I could get to work.
Caprice24
May 14, 2022Tutor
Hi Mikey Mikey94025 ,
Yes, the laptop connection Ethernet to Starlink V2. works just fine.
Here's a picture of the IP address with ipconfig cmd being run in Windows 11 Cmd line, followed by tracert to Google's DNS 8.8.8.8
Web pages load fine from the laptop directly connected to Starlink Ethernet
The problems begin when I insert Orbi into the loop.
When using Dynamic IP and regardless of whether I select Google DNS 8.8.8.8 or not, I don't get full access to the Internet through the Orbi. However ping works fine through the Orbi to Starlink, but not with network translation of websites, eg only IP addresses work, not for example www.yahoo.com.
Tracert does not work at all with IP addresses through the Orbi.
Here you can see ipconfig on Windows shows Orbi is giving my laptop an address of 172.16.0.2 and the gateway for Orbi is 172.16.0.1. And Tracert doesn't work.
Static IP configuration makes no difference on Orbi, still the same issue.
Mikey94025
Jun 06, 2022Hero
Caprice24 wrote:
Just guessing since we're grasping at straws here -- Could it be an IPV6 thing? Perhaps stick with Access Point mode (eliminate Double NAT, though you said before it still did not work) and then try disabling IPV6 in your Orbi, also try the different Internet Setup / Router MAC Address options (e.g., Use Computer MAC Address).
- FURRYe38Jun 06, 2022Guru - Experienced User
Ok, NG has said that since this is a StarLink issue, try setting a static route on the RBR for 192.168.100.1
Also need to ensure that the ip address for the Starlink is not on the same network as their other devices. Since the Starlink address will not change then in some cases they will need to change the third octet of their current dhcp server.
Let us know if this works.
- junior0415Jun 10, 2022GuideI just purchased the orbi 6e and tried to get ot to work with my starlink gen2 and had the same exact issue. After spending three nights on the phone with netgear tech support for 3-4 hours each time and them escalating it then escalating it again to their engineering department I was given no time frame for a fix. After much research online and trying everything I could find I decided to try a netgear gs108t switch. I plugged the switch in directly from the starlink ethernet adapter then the orbi 6e into that and it works perfect. Netgear definitely has an issue with the orbi working with starlink directly but this was the only work around I could get to work.
- FURRYe38Jun 10, 2022Guru - Experienced User
Even trying the Static Route configuration that was mentioned?
