Caprice24
May 14, 2022Tutor
Orbi 6e cannot connect to Starlink
 Well I wasn't able to get the Orbi 960 to get an Internet connection with Starlink V2, using the Starlink Ethernet adapter, so have filed a trouble ticket with Netgear. The unit is getting an IP addr...
- Jun 10, 2022I just purchased the orbi 6e and tried to get ot to work with my starlink gen2 and had the same exact issue. After spending three nights on the phone with netgear tech support for 3-4 hours each time and them escalating it then escalating it again to their engineering department I was given no time frame for a fix. After much research online and trying everything I could find I decided to try a netgear gs108t switch. I plugged the switch in directly from the starlink ethernet adapter then the orbi 6e into that and it works perfect. Netgear definitely has an issue with the orbi working with starlink directly but this was the only work around I could get to work.
Jubles
Jun 19, 2022Aspirant
I'm currently having the same issue. Did you come across a fix? I saw the post about a network switch, but that's about it for advice. Did I miss something?
Any help would be great.
Thanks,
Jubles.
Thanks,
Jubles.
junior0415
Jun 19, 2022Guide
No unfortunately the added switch is the only current fix that I know of.
