tuna_ertemalp's avatar
Mar 23, 2022
Orbi 6E Router RBRE960 only shows error on Access Control page
Just replaced my RBR50/RBS50 setup with a RBRE960/RBSE960 setup. Things worked pretty well. I did everything step by step over something like 6 hours, bringing my switches and devices online in secti...
  • TC_in_Montana's avatar
    TC_in_Montana
    Mar 25, 2022
    tuna_ertemalp
    Sorry it took so long to respond.  FURRYe38 asked me yesterday to take a look at this, but I was caught up in some other stuff and couldn't get to it until this morning.
    So, it appears doing your reserved addresses were done correctly.   Even updating the device names seemed to be done correctly.
    I do not think the number of entries is an issue - I have 29 devices with reserved addresses.  The only difference between how I did it and how you did it is I selected and updated them AFTER they were on the network.  But, then again, I used the same SSID as my prior router so they all automatically connected when I hooked up the 9xx series Orbi.
    The one BIG difference I see -  is that when I pull up the Access Control Tab, is that at the top of my Access Control Page - it says "To use access control, please use the Orbi App".    I am sure that is in hopes that people will use Armor/SPC for access control.   I personally don't use the Access Control but then again, I'm out in the country and pretty insulated/isolated from lots of internet traffic.   But I do believe all of the Access Control functionality has been moved over to SPC.
    I have seen in the past (not on the 9xx series) where people have updated the Device Name/Location on the attached devices page - and putting in special characters or too many lines of data has corrupted other screens that is trying to display device information.   All of this data is stored internally on the router and if something gets out of alignment, other things get out of whack.
    You might want to take a look again at your attached devices page - see if there any any special characters or extra long lines of data and modify it and see if that helps.
