TexARC
Nov 24, 2020Guide
Orbi 750 and 2.4gHz SSID
Is there any way to attach a 2.4gHz device (Ambient Weather Station) to Orbi? IOW, the device scans but cannot see an SSID for 2.4gHz. I'm currently on hold with the 6th tech support person at NetGe...
Nov 24, 2020Guru - Experienced User
Let us know if some of the suggestions work as well...
Check with the mfr of this device as well to see if they have any help and information. Ensure it's software or firmware is up to date.
TexARC wrote:
when I installed the orbi it did a firmware upgrade as part of the installation process, so I would have to guess from a distance that it is the latest version. I can check when I get home from work in about 12 hours. thanks.
TexARC
Nov 24, 2020Guide
all of the ambient weather stations rely on 2.4 GHz for connection to the router. if there is no way for orbee to provide an SSID for 2.4 GHz then that's a dead end. unless I can use one of the mesh extenders from Netgear which I mentioned in my original post? is there a way to connect one of these to orbi since they do differentiate a 5 and a 2.4 wavelength, that would be ideal. are Orbi and nighthawk mesh extender compatible?
- TexARCNov 24, 2020Guidei sm planning to plug a netgear ac1200 wac104 into one of the rj45 sockets on an Orbi satellite using a 10 ft cat 6e cable, with different SSIDs for it, does any see why that would not work or conflict with Orbi perhaps? Open to any and all suggestions. still have to say, the Orbi install process was VERY nice. Other than the surprise lack of a 2.4gHz SSID, of course. :)
- TexARCNov 24, 2020Guidealso, i have a 3 y.o. Ambient 1002, long to get the 2000....great stuff.
- TexARCNov 24, 2020Guidevajim, yes...i got the Orbi last night after trying and giving up on the netgear mesh extenders for my old netgear cable modem, then a spectrum modem plus synalgos router. i did just find a related thread up here with some good tips to try. eager to get home and try! thanks to all for help, will post results. the support from ed edleman of ambient weather is without equal, btw.
- vajimNov 24, 2020Master
Good luck Ron. I may have to look at that Ambient 2000
- FURRYe38Nov 24, 2020Guru - Experienced User
If the weather station is only 2.4Ghz then it will and should only see the 2.4ghz SSID signal. 5ghz will not even be used or seen by the device as it's incapable of detecting 5Ghz.
You can turn down the power output of the RBR from 100% to 25% and see if this helps as well. Also try disabling AX mode temporarily on the RBR to see if this helps.
TexARC wrote:
all of the ambient weather stations rely on 2.4 GHz for connection to the router. if there is no way for orbee to provide an SSID for 2.4 GHz then that's a dead end. unless I can use one of the mesh extenders from Netgear which I mentioned in my original post? is there a way to connect one of these to orbi since they do differentiate a 5 and a 2.4 wavelength, that would be ideal. are Orbi and nighthawk mesh extender compatible?- TexARCNov 25, 2020Guide
"You can turn down the power output of the RBR from 100% to 25% and see if this helps as well. Also try disabling AX mode temporarily on the RBR to see if this helps. "
I haven't found an option that provides control of the power output of the RBR, per se. I've made a bunch of changes to the default values, kinda thinking I am going to have to reset to factory to get everything back to the optimal settings. :)
I think I am going to have to wait to for the "regular" old-fashioned router to arrive and connect it. Just have to wonder
will it conflict with the Orbi
how far away do I need to put it from the source point (the satellite)
can it work off of the RJ45 socket on a satellite or does it need to be off the base unit
I think since I bought a Netgear router arriving tomorrow I hope, it should support the two MESH extenders, so I will end up being able to support a SENSE, Three SENSIBOs, 5 Nest cams, Two foscams, and the weather station. I also rely on the 2.4gz to reach 45 meters out to my patio by the lake, I haven't tested the reach of "Orbi" for that function yet...to be continued...now if I can just put all the settings back to nominal...
- FURRYe38Nov 25, 2020Guru - Experienced User
Under Advanced Tab/Advanced Settings/Wireless Settings
You want to use channels far apart from the Orbi on 2.4Ghz, Say Orbi set for channel 11 and your other 2.4ghz wifi router set to channel 1.
Place the other wifi router far appart from the RBR or RBS. 30 feet would be a good starting point. You might also set it's power levels as well to a low setting, if you can place it near this device. Then you should be ok.
