ymd
Aug 23, 2022Aspirant
Orbi 750 as cable connected wifi extender.
Hi, I moved to a new place with ethernet cables going from a central room into all rooms. I plan to use a switch and put my orbi devices into different rooms, all connected to this switch, for wifi...
- Aug 23, 2022
You should go
modem--->router---->switch/satellites
Otherwise if you're going modem/ont-----switch-----orbi (in router mode) the devices connected to the switch might be getting a public ip address from your ISP and not one of the private one from the router. Plus its less secure.
ymd
Does this apply?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System?article=000051205
I want to get this switch. Will it work?
https://www.newegg.com/netgear-jgs524-24-x-10-100-1000-mbps-twisted-pair-rj-45/p/N82E16833122058
- FURRYe38Aug 23, 2022Guru - Experienced User
Yes and yes.
