ymd
Aug 23, 2022Aspirant
Orbi 750 as cable connected wifi extender.
Hi, I moved to a new place with ethernet cables going from a central room into all rooms. I plan to use a switch and put my orbi devices into different rooms, all connected to this switch, for wifi...
- Aug 23, 2022
You should go
modem--->router---->switch/satellites
Otherwise if you're going modem/ont-----switch-----orbi (in router mode) the devices connected to the switch might be getting a public ip address from your ISP and not one of the private one from the router. Plus its less secure.
ymd
I'm not 100% sure but my Orbi does only router stuff. I was on comcast and before I have coax coming to a modem and then ethernet to orbi. I imagine that on fiber it would be similar that I'll have a fiber modem stuff but not sure.
So my setup would look like:
- ISP
- Modem
- Switch
- Orbi main
- Orbi satellite
- Orbi satellite
- Ps5 and stuff
Am I understanding correctly?
Also, I'm still fascinated that a switch can magically do all the traffic for me that it just works after I have ethernet plugged in and I can just sit back and enjoy its hard work. It's not like that the switch has a WAN port like on a router (and I don't understand the difference). Or have I missed anything?
ymd
Otherwise, should I do
- ISP
- Modem
- Orbi main wan
- Switch
- Orbi satellite
- Orbi satellite
- Other stuff
Not sure which should I do. Please suggest. Thanks in advance!
