ChaseA2017
Jan 05, 2023Aspirant
Orbi 750 Crashes During High Speed Downloads Over Ethernet
Experiencing this same issue, but on my RBR 750.
Hardware & Firmware Information -
Model - RBR 750 w/ 1 Sat
Firmware - V4.6.14.3_2.3.12
GUI Lang Version - V3.0.1.54._2.1.30.3
Internet...
iyang
Jan 09, 2023NETGEAR Expert
Hi ChaseA2017 ,
Which game do you download ?
which devices do you use ? ex: android/iOS device, laptop, macbook,...
Thanks.
- ChaseA2017Jan 12, 2023Aspirant
Wide variety of games. Not sure how that's relevant.
Devices are primarily windows & potentially android or Mac (in terms of Apple TV and Firestick). My PC is the bandwidth hog.
Its never been an issue before and considering this has occurred right after a firmware update, I'm thinking that's the reason why...
- FURRYe38Jan 12, 2023Guru - Experienced User
Yes you can re-enable Armor after testing. Be sure that when you disable Armor that you power OFF the RBR for 1 minute then back on.
Were getting posts that users are disabling Armor and is stopping the router from crashing when downloading large file size games.
